I want to add an edge to the array to show that its a closed grating.
The edge needs to be the same thickness as stated in the grating, so for 20x2 the edge thickness needs to be 2 mm.
For easy usage i want to have it when you drag the upper right side to a position, it automatically snaps to a position which keeps the shape of the grating inline with the thickness of the outer edge.
That way you don't have to calculate or try to find the sweetspot.
In the drawing attached i have made 2 examples of what i mean,
The first one on the left uses a incline of 22 for the outer edge, but when you drag it to a particular length, this distance for the right and upper side increases from the 2 mm i want.
The second one on the right is exactly made as the first one, but with this one i have calculated what the distance needs to be for the edge to show it's thickness of 5mm, but i want to make this automatic.
If you need more information just say and i will try to explain it.
