Grating Outer edge thickness
I want to add an edge to the array to show that its a closed grating.
The edge needs to be the same thickness as stated in the grating, so for 20x2 the edge thickness needs to be 2 mm.
For easy usage i want to have it when you drag the upper right side to a position, it automatically snaps to a position which keeps the shape of the grating inline with the thickness of the outer edge.
That way you don't have to calculate or try to find the sweetspot.
In the drawing attached i have made 2 examples of what i mean,
The first one on the left uses a incline of 22 for the outer edge, but when you drag it to a particular length, this distance for the right and upper side increases from the 2 mm i want.
The second one on the right is exactly made as the first one, but with this one i have calculated what the distance needs to be for the edge to show it's thickness of 5mm, but i want to make this automatic.
If you need more information just say and i will try to explain it.
Nevermind guys,  Already figured it out on how to solve this issue. Lol
lena.talkhina
Hello @Anonymous !
Don't hesitate to share a solution with us - it will help other users to find answers on the same question faster.
Thank you!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Forgot to include it, didn't even realise it. Here is the block with the solution.
I needed to adjust the positions of the parameters controlling the arrays of the block.
