Type SP Grating side view array
For my Type SP grating side view dynamic block i have a issue with the array of 2 different objects,
I want to have it when you increase the length of the grating by 1 step(20 mm), another row of 1 object, either the small one or the longer one, shifts to the correct position.
When you drag to extend the grating it doesn't correctly place the small object to its position, this only works when you shift it another step forward, when a longer one needs to be in the position.
Does this issue have to do with the distance between the arrays, or with the placement of the parameters?
Thank you for the help
Found the solution. I find after posting to the forum the solution directly.
Change the position of the parameter array left 20x2 and it will work
h_s_walker
It's the placement of the arrayleft 20x2 parameter.
Because your array length is 40 with a stretch of 60 it's less than 80 so the second object will not appear. Make the Start X of the array -40 so the length is 60 and your array will work
Howard Walker
Left Handed and Proud
