Specify number of items of array with lookup table (dropdown)
Intuos5
Advisor Advisor
Intuos5
I have a file with two nested blocks, with two visiblity states for showing either item A or B. I would like to array them and specify the number of items from a drowdown. I set a linear parameter and array action for each, so they array independently. How do I associate a number dropdown for the item number to the array?
h_s_walker
See the attached drawing for an example. The bottom grip controls the circle. The top grip controls the square
Howard Walker
Left Handed and Proud
Intuos5
The one thing I don't understand is when I recreated the lookup parameter with a lookup action, I was not able to enter values for the lookup, despite having set the distance 2 parameter (following along a tutorial). Could you tell me how these values are supposed to be inserted in the lookup table?
h_s_walker
Can you post your drawing.
As to the lookup. The input property needs to be the distance, and the value needs to be the total distance for the number of items you need to array. So if the items are arrayed every 10 your distances need to be multiples of 10. See the image below
Howard Walker
Intuos5
Ah, I see, I can just type in the values for the lookup. Nvm, thank you!
E: Final question: can this by any chance be automatically filled in?
h_s_walker
No you need to do it manually
Howard Walker
