Dimension issues (Position)
martin.cappe
martin.cappe
Is it possible to move a dimension when she's in a Dynbloc ? 🤔
Capture d’écran 2020-12-08 111749.pngMy goal is to avoid this case.
I just want some parameters that can move the dimensions text etc...
Notice that the bloc have a lot of parameters.
You will find the bloc under the message, the bloc is pretty simple I think.
CM
Libbya
You can certainly add linear parameters with stretch actions to allow you to adjust the dimensions.
martin.cappe
But as you can see in the video I just made, the rotation is not following properly. (Yes, the block in the video is a bit more sophisticated as the previous one, but it's pretty much the same).
Tell me if you want some more details. 🙂
Thx.
CM
EDIT : the video is not working...try to rotate the block you will understand I think
