Sheetset Manager - Sheet Views / Place Callout Block
mmichel6UEHA
mmichel6UEHA
I broke my brain making a block that is interactive with the sheet set manager. My intention is to have (at least two??) blocks that, one is similar to a multileader and calls out something, eg. (1/C10.0) LIGHT DUTY ASPHALT PAVEMENT . Then on C10.0, I'd have just (1) LIGHT DUTY ASPHALT PAVEMENT.
I was generally successful on this as indicated above, but then I started thinking and tinkering with how this might would with a detail "template" (a dwg of all the detail views). Once I import a template of the view and respective blocks, the sheet views are "broken" and must be renamed and renumbered. I am not excited about the idea that I'd have to rename & renumber every detail that I need to call out.
How do you guys accomplish this? Any other pointers or recommendations, even if its a youtube link or forums link would be greatly appreciated.
Thank you!
lauri_barnhart
Hello, @mmichel6UEHA.
Hope you are well. Just checking in to see if you found any helpful guidance for the question above. If you did, please update us here. If you still have questions and need help, please provide an update here also.
Best,
Lauri | Community Manager
mmichel6UEHA
I have not found any information on the creation of templated sheet views and how they relate to ssm.
mmichel6UEHA
I believe the answer to the question:   how this might would with a detail "template" (a dwg of all the detail views). Once I import a template of the view and respective blocks, the sheet views are "broken" and must be renamed and renumbered.
The problem is better phased as such:
Detail-number/callout blocks still point to the old Sheet Set after a drawing is copied into a new Sheet Set.
Without it:
  • blocks keep the old .dst path and old Sheet View GUID;
  • fixing dozens of details would require manually reinserting or relinking each one.
I believe the answer is to create an AutoCAD .NET API script that:
  • Searches model space and every layout.
  • Finds every block named exactly: *whatever your block is named*
  • Reads each block’s *whatever your sheet view is that is comparable to the model view* value.
  • Finds the matching Sheet View in the destination Sheet Set.
  • Updates the block’s Sheet Set fields:
    • database path;
    • Sheet Set GUID;
    • Sheet View component GUID.
  • Refreshes the title and detail number fields.
