- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I broke my brain making a block that is interactive with the sheet set manager. My intention is to have (at least two??) blocks that, one is similar to a multileader and calls out something, eg. (1/C10.0) LIGHT DUTY ASPHALT PAVEMENT . Then on C10.0, I'd have just (1) LIGHT DUTY ASPHALT PAVEMENT.
I was generally successful on this as indicated above, but then I started thinking and tinkering with how this might would with a detail "template" (a dwg of all the detail views). Once I import a template of the view and respective blocks, the sheet views are "broken" and must be renamed and renumbered. I am not excited about the idea that I'd have to rename & renumber every detail that I need to call out.
How do you guys accomplish this? Any other pointers or recommendations, even if its a youtube link or forums link would be greatly appreciated.
Thank you!
