Text attribute in dynamic block not moving.
wjmdesigns
Message 1 of 8
wjmdesigns
I created a dynamic block with several text attributes.  Everything moves correctly when the dynamic block is moved using the "MOVE" command.  But, a couple of the attributes do not move with the dynamic block if moved using the "grip".   The two that I'm having a problem with are labeled inside the block as NOTE_E_V and NOTE_I_H.  Otherwise the block is working as expected.  Could someone please help me identify what's wrong with these two text attributes?
Replies (7)
Message 2 of 8
kiran_cadexcel
This is a very common dynamic block problem —
THE CAUSE:
Attributes in dynamic blocks do not move
automatically with stretch or move actions
unless you specifically include them in the
action selection set.
This is the most missed step when creating
dynamic blocks with attributes.
THE FIX — Step by step:
Step 1: Open Block Editor
Type BEDIT → select your block → OK
Step 2: Find your Move or Stretch Action
In the Block Editor look for the action
symbol (lightning bolt icon) on your
canvas — double-click it to edit
Step 3: Check the Selection Set
When you created the Move or Stretch action
you selected objects to include.
Your ATTRIBUTE was probably NOT included
in this selection.
Step 4: Edit the Action Selection Set
• Double-click the action (lightning bolt)
• AutoCAD highlights currently selected objects
• Press Add Objects button or type A
• Click on your ATTRIBUTE text to add it
• Press Enter to confirm
• Click OK
Step 5: Test the block
Close Block Editor → Save
Insert the block → test the action
Attribute should now move with the geometry
ALTERNATIVE FIX — Delete and recreate action:
If editing the selection set does not work:
1. Delete the existing Move/Stretch action
2. Recreate it from scratch
3. When AutoCAD asks "Select objects for
   action" — carefully select BOTH the
   geometry AND the attribute
4. Press Enter to confirm selection
5. Save and test
IMPORTANT RULE I follow:
When creating any dynamic block action —
always select ALL objects including:
✔ Geometry (lines, rectangles, arcs)
✔ Attributes (text attributes)
✔ Grip points if needed
If even one object is missed from the
selection set, it will not move with
the action.
SPECIAL CASE — Attribute moves but
text position resets:
This happens when attribute has a
fixed insertion point in the block
definition.
Fix:
• Open BEDIT
• Double-click the attribute →
  Attribute Editor opens
• Check "Lock Position" checkbox is
  UNTICKED
• If it is ticked — untick it → OK
• Save and test
ANOTHER COMMON CAUSE —
Attribute on wrong layer:
If your attribute is on a frozen or
locked layer inside the block editor,
actions will not affect it.
Fix:
• In BEDIT check your layer panel
• Make sure attribute layer is
  thawed and unlocked
• Move attribute to same layer as
  geometry if needed
VERIFICATION CHECKLIST:
Before saving your dynamic block always
check:
☐ Attribute included in action selection set
☐ Lock Position is unticked on attribute
☐ Attribute layer is thawed and unlocked
☐ Action type is correct — Move not Stretch
   if attribute should move without stretching
☐ Test all grip positions before saving
— L. Kiran Kumar
AutoCAD since 1997 | Modular Furniture
Specialist since 2006 | Hyderabad, India
[email protected]
Message 3 of 8
h_s_walker
@wjmdesigns Can you show us which grips are supposed to be moving the text
Howard Walker
Left Handed and Proud
Message 4 of 8
wjmdesigns
I appreciate you following through with step-by-step instructions.  However, I don't think the problem I'm experiencing is in the move or stretch function within the block.  When I click on the dynamic block a grip for the block shows up which is also the insertion point of the block.  If I click and hold the insertion grip to move the block the two attributes mentioned earlier do not move when the block is dragged using the grip.  I've been using the move command to move the block since first experiencing this problem but it would be easier to click and drag using the grip.
Message 5 of 8
h_s_walker
@wjmdesigns There was something wrong with your "...-i" attribute, so I've recreated it, also you do not need a basepoint parameter in the block if you are not moving the basepoint from where it is originally set. See the attached drawing
Howard Walker
Message 6 of 8
wjmdesigns
Do you know what was wrong with the original attribute or was it simply just one of those things?  I only put the base point inside the block so I could quickly see where the basepoint of the block was.
Message 7 of 8
h_s_walker
@wjmdesigns It was just one of those things. Before I deleted your attribute, I made sure the attribute I created had all the same properties as yours.
Howard Walker
Message 8 of 8
kiran_cadexcel
Hi Howard Walker,
I want to be transparent with the community.
In my past experience of creating furniture block libraries with attributes,
I personally have not encountered this specific problem in my own drawings.
However based on my deep knowledge of dynamic blocks and attributes, the methods I shared are the correct approach to investigate and resolve attribute
movement issues.
If those steps did not solve your problem,
please share:
1. Which AutoCAD version you are using
2. How you created the action — Move or Stretch
3. Did you add the attribute before or after
   creating the action
4. Screenshot of your block editor if possible
With these details I can give you a more
specific solution.
— L. Kiran Kumar
