Scale Block Linework With Rotation for different X/Y Scale
Is there a way to scale a block as you rotate it. We have profile views which have a 10x exaggeration in the Y direction. So we have a block that matches at 0% slope, but once you start to rotate it due to the difference in X vs Y scale the display length needs to reduce with rotation to stay correct.
Example at 0% the block is correct
But as you rotate and have more of an x dimension at a different scale where the displayed length would need to reduce causing the block to start to not match up with the pipe structure.
you can insert the block then change x or y as you want also you can change angle value .......but the better after scaling the block you can align it as separate step.
