Dynamic block attribute has zero highlighted
Hi everyone,
I've created some dynamic blocks which have text attribute that changes based on block properties table selection.
When I insert that block default value is 0 and its highlighted, then I change it to B10A and zero is still highlighted and whenever I use FIND to find similar blocks, blocks with highlighted zero are not found. Manual solve for that issue is to change attribute to any value that has no zero in it, like B13A, and then revert to B10A. Problem is that when I copy that latest B10A, that doesn't have highlighted zero, a pasted block gets zero highlighted again.
So is there any solution for that?
I will post some pictures here.
Bump
