Dynamic Blocks Forum
reset block with align parameter
1 REPLY 1
chaintec2
173 Views, 1 Reply
I have a block with some features in it as rotate, stretch and visibility
and also an alignment parameter
If I do a reset all is reset except the angle that was set for the alignment
how to reset also this
Tags (1)
1 REPLY 1
hwalker
in reply to: chaintec2
If you're using a rotation parameter I wouldn't use the alignment parameter. They don't work well together. The alignment parameter rotates the whole block. If you want it all back to 0 you need to actually change the block rotation. See the image below
Howard Walker
Left Handed and Proud
Forma Design Contest
AutoCAD Beta
