Dynamic Blocks Forum
Viewport inside the block
4 REPLIES 4
GD.ON
267 Views, 4 Replies
Hi there!
No idea of how to call it, so decided on "viewport inside the block".
Received client's drawing with interesting feature I'd like to adopt, but no idea how this is created.
There is a frame in the model space working as a viewport. Anyone can help me understand how this is done?
dwg file attached.
4 REPLIES 4
hwalker
in reply to: GD.ON
Your client has used the command CLIP to only show part of the block. See the following links
CLIP (Command) | AutoCAD | Autodesk Knowledge Network
About Clipping External References and Blocks | AutoCAD | Autodesk Knowledge Network
Howard Walker
Left Handed and Proud
GD.ON
in reply to: GD.ON
Brilliant
Thank you!
ElSid
in reply to: hwalker
Really, This looks like a named view (newer 2019ish feature). In model space, you name a view and when you go to paper space, you can NOW use that view name AutoDESK Named Viewports
hwalker
in reply to: ElSid
Nope it's a block which has been clipped. You can tell it is something which has been clipped, by the blue arrow
Howard Walker
Autodesk Customer Advisory Groups
”Boost
