Redefining dynamic with hatch
leticia.campanelli
872件の閲覧回数
10件の返信
メッセージ1/11
leticia.campanelli
Hi there,
I am wondering if there is a setting to avoid the messing up the hatches in the dynamic blocks once they are redefined.
before redefined
After
As you can see below, the lines are ok but the hatches are all over the place.
thanks
0 件のいいね
解決済み
873件の閲覧回数
10件の返信
返信 (10)
メッセージ2/11
j.palmeL29YX
1: The hatches must be assoziative.
2: I'd prefer to choose object(s) (instead of picking inside ) to create the hatch(es).
Both we can not see in your images.
For more (better) help post your dwg file please.
BTW: What do you mean with "redefined"?
Jürgen Palme
0 件のいいね
メッセージ3/11
leticia.campanelli
The hatches are associative, but I picked the inside.
the block works fine, I added a new visibility state needed to redefine using the Design center/blocks - that is when the problem happened.
I choose redefine to add the new visibility state - it change the hatch.
I can do it manually one by one after...but it is time consuming - As you can see above I have 72 instances in this particular file.
see file attached.
0 件のいいね
メッセージ4/11
j.palmeL29YX
As a first attempt I would remove all hatches from all actions's selection sets where they are included.
Furthermore I find two hatches which fill the default rectangle. I'm not sure if you really need both (?).
(untested)
Jürgen Palme
0 件のいいね
メッセージ5/11
Ed__Jobe
Can you use a previous version? Find the bak file? Or if you haven't saved the host file yet, click undo.
Ed
How to post your code.
0 件のいいね
メッセージ6/11
leticia.campanelli
I just want t make sure the hatch updates with the lines as it is an associative hatch, I don't understand why it doesn't.
0 件のいいね
メッセージ7/11
j.palmeL29YX
I think this is a bug. If you redefine a block definition which contains one or more hatches, the hatches are not updated automatically. Not the new visibility state causes the problem. Each simple modifying of the block definition leads to this trouble.
The only solution I found. Select each existing blockreference, pick one of the dynamic grips, move a little but place it again at the same point. This updates the hatch and all is "fine" (but with a lot of work to do that).
Jürgen Palme
0 件のいいね
メッセージ8/11
j.palmeL29YX
解決済み
I found a way to update all block references at once.
After you have redefined the block definition in your current drawing (and see the not updated hatches), open the blockeditior to edit the blockdefinition in your current file. Change nothing, but save the block definition again. After leaving the blockeditor all block instances are updatetd correctly.
If you need I'd like to show you a video ...
Jürgen Palme
メッセージ9/11
leticia.campanelli
that is what I have been doing, it is just annoying.
0 件のいいね
メッセージ10/11
leticia.campanelli
Thanks! That works well.
0 件のいいね
メッセージ11/11
TomHia
I can confirm both - the bug exists and this is the way to deal with it.
Thank you! I'd like to point out, that I had to edit/save the block definition twice to "fix" every instance. Part of the drawing was not updated after first edit.
0 件のいいね
