Dynamic Blocks Forum
Rebar
10 REPLIES 10
Message 1 of 11
adper27
831 Views, 10 Replies
Rebar
Hi all
Have anyone knows how to add value or dimension to my rebar dynamic block? I have seen a block also from this forum and that text or value was in field. How I can do that using the field or is there an easy way? See below image.
many thanks in advanced.
Tags (1)
10 REPLIES 10
Message 2 of 11
Libbya
in reply to: adper27
POST THE BLOCK with any inquiry.  The image file is not helpful, the block file is essential.
There are various ways.  Probably the easiest way would be to add an actual dimension to the block.
Message 3 of 11
adper27
in reply to: Libbya
attached block below..
Message 4 of 11
hwalker
Study the attached block it's Shape Code 44
Howard Walker
Left Handed and Proud
Message 5 of 11
adper27
in reply to: hwalker
thanks, when I stretched the block. why is the value or the length of a segment still fixed to the default value.
Message 6 of 11
hwalker
You need to do a regen and then the values will update.
They're linked to lines on the defpoints layer which are stretched when the relevant line is stretched
Howard Walker
Message 7 of 11
Libbya
As I mentioned in my first post, dimensions are probably easier than fields if they can work.  In this case, I believe they can.  Here's hwalker's block with dimensions added for the text rather than using fields.  The advantage is that the values update immediately without any regen.  The downside is the little dots at the dimension points.
Message 8 of 11
hwalker
in reply to: Libbya
The problem with using dimensions is that when doing reinforcing it needs to be rounded to the nearest 5mm for individual lengths or 25mm for the overall length, which is what my field codes do.
And there are lots of other fiddly calculations to do as well, which is why your 1035 dimension for the total length is wrong.
Here is the calculation.
L=A+B+C+D+E-2r-4d
R=12 D=6
Howard Walker
Message 9 of 11
Libbya
Hwalker, I'm not familiar with the needs of rounding off rebar lengths, but what you describe (accurate rounding) is much more easily doable using dimensions than formula fields.
The block you posted does not seem to do what you suggest, though.  The actual value of A and E is 248.  The actual length of B and D is 146. The actual value of C is 246.  The actual value of A+E+B+D+C=248+248+146+146+246 = 1034.  IF rounded to the nearest 25mm, that would equal 1025, not the 975 your field block displays.
My last block also had an error in calculation due to the way it was set up, but I had all rounding to the nearest 5mm.
Here is a version that rounds each to value to the nearest 5mm and the overall length to the nearest 25mm.
Message 10 of 11
Libbya
in reply to: Libbya
Ah, I just caught your description of the added curve values.  As I said, I'm not at all familiar with the way rebar is measured or the values need to be displayed and so I'll abandon my attempt at guessing how the desired value is arrived at.  Regardless of that, IMO it is still easier to achieve the necessary formula values using dimensions than using formula fields and the added bonus is the immediate displayed value.  The downside is the dots.
Message 11 of 11
in reply to: Libbya
@Libbya
Sorry for posting an off topic post.  I was trying to send you a PM regarding my suggestion to nominate you to become an Expert Elite due to your long time valuable contribution but your PM is disabled.  If you are interested, please message me back.
-Toan
Forma Design Contest
AutoCAD Beta
