I have this very annoying problem. My company makes concrete products and we use huge amounts of rebar and we have to detail this on our drawings. I have made dynamic blocks to represent the bar these are 1:1 and stay 1:1 never scaled they work very well. I would like to put a leader with a balloon and an attributed text for a callout number on the bar but I cannot make the arrowhead and circle annotative which it needs to be since our drawings are in different scales. I have attached a drawing with one of the bars shown.
Have you tried making the Leader an Annotative block? Or DynBlk?
You may actually be hung up trying to use a multi leader in this environment. Have you tried one of the included annotation tags?
And I am not an annotative user. Hopefully someone who uses annatation within viewports will come along to chime in.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
So you are nesting the Leader inside the Rebar block? Yes, I do not believe what you seek can be done.
as I read from a book circle cannot be annotative. yes leader or multileader can be annotative. just passin by..hope It helps..
