Problem with script use
Whenever i am making a group and i am using the script to rotate it . Its showing invalid base point. Can anyone tell the reason for the error.
pendean
Community Legend
Community Legend
And your script code is... ?
rotate
g
1
0.0000,0.0000
-1
rscript
This was my script code of simply rotating a line endpoint at origin.
pendean
Community Legend
Community Legend
I see you have the script set to run continuously by default: which instance of ROTATE command fails?
Its telling invalid base point.
h_s_walker
Run the script again. Press F2 to bring up the command window and then post a screenshot of that so we can see what it thinks the "basepoint" is.
Howard Walker
Left Handed and Proud
