Dynamic block with multiple rotation points - How to rotate points with block?
Hi all.
Very new to autoCAD.
I have setup a dynamic block with multiple rotation points, one on each of the objects 5 corners.
However, when I rotate from one of the corners, the grips of the remaining rotation points do not rotate with the object itself and are left floating behind.
Is there a way to have them remain with the object as it rotates?
I have attached 2 screenshots. First shows the setup of my block. The second shows what happens when rotated from the top left rotation grip.
Couldn't find anything regarding this via my searches on these forums and the wider internet, so hope this is an appropriate question!
Many thanks
h_s_walker
You need to add the rotations to the other rotations. See the attached drawing
Howard Walker
Left Handed and Proud
peterjwinberg
In other words, when selecting which objects you want to rotate with each action, make sure you include all of the other rotate parameters as part of your selection set along with the line work.
"Add the rotations to the other rotations."
Thank you!
Exactly what I was after.
Didn't realise you could select 'Parameters' in the same way as objects. Makes sense!
My Dynamic Blocks are coming along nicely!
