Hi, I am trying to put a polar stretch on the block uploaded, but it dosent seems to work (maybe because of myu constraint? ). If something major is wrong with it, is there another way I can make the same drawing proportional when i rotate it and stretch it ? Also, after that I have to use it for vlisp.
Thank you in advance
Demoiselle_en_détresse (which means, lady in distress in french)
Solved by Charles_Shade. Go to Solution.
As a start is this the basic function you are looking for?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Yes, I only want to position it in any direction that is required with vlisp (automotically)and attribute it a value that can see on autocad.
Polar Stretch has two parts to it: Stretch Entitites and Rotate Entities.
After you pick the Stretch Frame and hit Enter you Select Objects to Stretch and then when you hit enter you need to choose Objects again because that is the Rotate portion of the Action then hit Enter a third time to end the Action.
Polar Stretch is the only Action that has two parts to it and it is easy to lose or otherwise get this mixed up.
I suspect that you are not choosing the Attrib twice in the Selection set and/or the Attrib is not Locked and therefore will not follow the Action.
