Dynamic Blocks Forum
Point parameters not moving after block table choice
9 REPLIES 9
Message 1 of 10
WfZC9JJ
503 Views, 9 Replies
Hi all, and thanks for reading in advance.
I have a dynamic block that changes based on a blocktable.
However the 4 point parameters arn't updating their coördinates
see below, (left) first option  and (right) another option.
I did gave them coördinates, so I don't know whats going on
update: I wrote them away and reinserted the block, but no change
Labels (2)
9 REPLIES 9
Message 2 of 10
JBerns
in reply to: WfZC9JJ
@WfZC9JJ,
I think you may need a stretch action, but I'm not certain.
The Dynamic Block expert, @Libbya , will likely be able to assist.
By the way, there is a dedicated forum just for AutoCAD Dynamic Block assistance.
https://forums.autodesk.com/t5/dynamic-blocks-forum/bd-p/154
Jerry
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 3 of 10
hwalker
Why do you want those points in the first place?
Using them to move the "linework" around is a bit of bad practice in that you can move them anywhere even "a million miles" from the basepoint of the block which would totally mess up your drawing.
I'd just remove them and use an intersection snap on the two lines in the circles if I wanted to move the linework around.
Howard Walker
Left Handed and Proud
Message 4 of 10
WfZC9JJ
in reply to: hwalker
The basepoint is moving along with everything else, I don't really see a problem in messing anything up.
Using move with an intersection snap isn't really the workflow I'm going for here.
thanks for the feedback though
Message 5 of 10
WfZC9JJ
in reply to: JBerns
Thanks, I'm looking into it
Message 6 of 10
hwalker
But your basepoint isn't moving with the block, it's staying at 0,0 (see the first two images below). And then if you change the state using the block table it breaks the block even more (see the third image).
Howard Walker
Message 7 of 10
WfZC9JJ
I noticed that after I posted the block but I already updated it?
Or thought I did, it's moving along fine here, check the latest block
Message 8 of 10
Libbya
When a block properties table changes the position of a point parameter, any actions associated with that point parameter are activated for the change in position.  You have 4 point parameters and each of them move EVERYTHING in the block, including the other point parameters!  The four move actions combine to cancel each other out.
Message 9 of 10
Libbya
in reply to: Libbya
Here's probably the easiest way to get it all working the way you want.  See screencast:
Message 10 of 10
WfZC9JJ
in reply to: Libbya
Wow did not know about the fact it also activates the associated actions as well, that's some deeper knowledge.
So you use the new points to balance it and knudge them in the right directions. I'll try and recreate it
Thanks alot, really appreciate the help, this keeps me moving forward in understanding dynamic blocks.
I probably also could have set new points per visibility, but that would've been 4x8=32 points.
But the less the better that's why I tried this approach. Thanks for dotting the i's
Autodesk Customer Advisory Groups
”Boost
