Dynamic Blocks Forum
Dynamic block doesn't show Visibility state anymore..
2 REPLIES 2
tojessesmit
314 Views, 2 Replies
Hi Guys and Galls,
First of all, my apologies for any typo's and rookie question's.
Could anyone help me out here? I'm trying to get into Dynamic Blocks, there's no AutoCAD veteran at my company so i'm figuring things out as we go.
I've made a Dynamic Block for different drilling points in a cabinet. After successfully making the Dynamic Block, i tried to add text as an Attribute so i could alter the text: "AFVALKAST 800 / 600 / 590 / 18". This is where it all went wrong, now the Dynamic Block shows a grip point in the middle, and it looks like your regular Block.
I've tried to delete the Attributes, without any luck..
The Visibility state dissapeared, though the Visibility states are still visible and useable via Properties -> Misc -> Vis1.
Probably an easy fix, but i just can't find the solution..
(Unrelated question: Is it possible to enter/alter Attribute text such as length/width so the Dynamic Block would change with it? Asking for a friend)
2 REPLIES 2
hwalker
in reply to: tojessesmit
Somebody has "made" your block a "group" just select it, right click. Move down to the GROUP section and choose UNGROUP
Howard Walker
Left Handed and Proud
tojessesmit
in reply to: hwalker
@hwalker
Facepalm...
Thanks!
Autodesk Customer Advisory Groups
”Boost
