I have a dynamic block with three visibility states (attached).
In the default state, everything's fine, but when I switch to one of the other states, the scaling and stretching parameters disappear.
Other than switching back to the default state every time I want to scale or stretch, is there a fix for this?
Solved by Libbya. Go to Solution.
Yes, there is an easy fix. Make the parameters visible in whatever states you want their grips to show.
It also might be more user friendly if the two actions were independent so you did not have to resize after scaling. Here's how to implement that if desired.
Oh, that was too simple. Thanks!
As far as making the actions independent, you basically read my mind, so thanks for that too.
