Dynamic Blocks Forum
Parameter visibility
3 REPLIES 3
strawberry12
428 Views, 3 Replies
I have a dynamic block with three visibility states (attached).
In the default state, everything's fine, but when I switch to one of the other states, the scaling and stretching parameters disappear.
Other than switching back to the default state every time I want to scale or stretch, is there a fix for this?
3 REPLIES 3
Libbya
in reply to: strawberry12
Yes, there is an easy fix.  Make the parameters visible in whatever states you want their grips to show.
Libbya
in reply to: Libbya
It also might be more user friendly if the two actions were independent so you did not have to resize after scaling.  Here's how to implement that if desired.
strawberry12
in reply to: Libbya
Smiley Embarassed Oh, that was too simple. Thanks!
As far as making the actions independent, you basically read my mind, so thanks for that too.
Forma Design Contest
AutoCAD Beta
