Dynamic Blocks Forum
Object Visibilities Within Dynamic Block
2 REPLIES 2
QJaworski
119 Views, 2 Replies
Is there any way to control the visibility of an individual object within a dynamic block instead of having to create a visibility state of every possible outcome?
For example, let's say I have a dynamic block shaped as a hexagon. At each vertex of the hexagon there can be a circle, a square, a triangle, or nothing at all. I would like to make it so that there is a selection menu for each vertex rather than having to create a visibility state for every one of the 4096 outcomes. Is there a way to do this?
2 REPLIES 2
Libbya
in reply to: QJaworski
You can use scale actions coupled to lookups in order to scale objects down to a size so small they show up as a point or scaled up to normal size based on selection.  The point that the objects scale down to can be placed in a location where another item is visible so they are hidden.
hwalker
Here's an example of what @Libbya is talking about
Howard Walker
Left Handed and Proud
Autodesk Customer Advisory Groups
”Boost
