Block attribute that has a field referenced to another attribute in the same block to subtract
bgraverholt
bgraverholt
So I'm trying to create a block where I want to change 1 attribute and it will update the other attributes via field formula located in the block. No mater what I have tried, when I change the DB attribute and hit regen or attsync the other attributes in the block wont update. I have also tried using dtext instead of using attributes for the other values and still couldn't get it to update. The attached drawing/image below has the block with boxes around with leaders explaining it a little more. I was able to get them to update but I to do that I have to edit the attributes after inserting the block in a drawing via the attribute editor and redo the field reference DB attribute. But in the long run I want to put this block in tool palette and insert it into a drawings so I would need the it to work with the default attribute values. If I cant use attributes to accomplish what I what I want to do is there another way I can get this to work??
Replies (8)
Libbya
Your issue is probably one of the top 10 most common issues posted on this forum.  The answer is fairly simple.  Fields within blocks will not update until you perform a dynamic action.  Your block does not have any dynamic properties so you obviously have not performed any dynamic action.  In the following screencast I add a user parameter to your block.  After that, I change that user parameter value as the dynamic action and the fields work.
To be clear, a dynamic action only needs to be performed once for a new insertion.  The block fields will work from then on.  If you copy a block that has had a dynamic action performed, the fields in the copy will work fine.  If you create a tool palette tool from a block that has had a dynamic action performed, then the fields will immediately work for all blocks inserted using that tool.
Libbya
bgraverholt
WOW that's all I needed to do?.... I knew there had to be a way to make it work! I couldn't see a reason why AutoCAD couldn't do what I was trying to do haha! How I ended up making it dynamic was instead of user parameter I just creating a visibility with a stop visibility (default) and Start visibility so user can just use the pull down and click on the start visibility! Thank you so much for your help on this!!
OliverE
Is there a specific reason why a block needs to be dynamic in order to update these types of fields? Seems counter intuitive.
Additionally, can anyone provide a solution to a similar problem I'm having using Callout and Label Blocks with the Sheet Set Manager? I've created the blocks in the attached dwg for use with SSM. I'd like the Label Block to display the Sheet Title of where the Callout Block is inserted. I have not been able to find anything that suggests there is a simple solution to this issue using the built in SSM functionality, presumably because you can insert multiple instances of the Callout Block on different Layouts so the Label Block would not know which location to reference.
However, I figured there might be a way to achieve what I want with a little manual adjustments made after an instance of each block has been created within the drawing. Therefore, I have tried inserting both blocks into a sheet that is part of the associated Sheet Set so that instances of both exist within the drawing. Then selecting the attribute I'd like to change on the Label Block and right-clicking in its value entry box -> Insert Field -> Object -> Select Object. However, I cannot select the Callout Block if it is on a different Layout or location to the Label Block.
It would be great if there were a solution that didn't require the additional steps after inserting each block and was hoping this was maybe achieved by adding a dynamic feature such as a Visibility State in the block's definition within the Callout/Label block dwg that gets added to the Sheet Set as a property.
Any help would be greatly appreciated.
C3D2021, Windows 10
Libbya
I don't know the reason why the code functions the way it does.  I agree that it would be more intuitive (and better) if fields just worked without jumping through secret hoops to get there.  I just know how it works and the hoops to jump through.
That said, you CAN create a very easy way to insert blocks with the fields already functioning.  Just make a tool palette tool that already has the field(s) working.  The tool palette is always convenient docked to the side and is IMO the quickest/easiest path to block insertion.
OliverE
Are you suggesting doing away with the SSM entirely? What do you mean by "make a tool palette tool that already has the field(s) working"?
Libbya
I made no suggestion regarding SSM.
If you make a tool palette tool from a block that has already had a dynamic action performed so the fields update, then all insertions made using that tool will have the fields working immediately upon insertion and do not need any dynamic action performed.
OliverE
Ok, I see what your saying. However, I don't think this would work when using those blocks for use in the Sheet Set Manager as Label and Callout Blocks since the Label and Callout Blocks are defined in a drawing outside of the drawings that make up your sheet set.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
