Dynamic Block with Stretch Linear with rectangle and hatch
C_Wauw
C_Wauw
I’m having trouble inserting a dynamic block with a stretch linear1.
I have created a dynamic block of a rectangle. This rectangle contains an associative hatch (hatch). During testing, it works perfectly. When I insert this block into my drawing and change the length of the block, it works as it should.
However, when I insert the same block again into the drawing, the properties of the hatch of the first block lose their values and are reset to the default settings.
How can I ensure that the hatch of the first block remains the same when adding a second or third block??
h_s_walker
I have noticed that in some of my blocks as well.
I haven't tested this solution that I read about though.
Instead of hatching using the "SELECT INTERNAL POINT", choose the "BY OBJECT" selection and it should stretch as normal
Howard Walker
Left Handed and Proud
