Dynamic Blocks Forum
multiple visibility parameters in a block.
2 REPLIES 2
730 Views, 2 Replies
Hello
I want to know if today someone have a solution for add multiple visibility parameters in a block.
If it possible to do it with autocad 2017.
thanks for your reply.
2 REPLIES 2
krzysztof.psujek
there was a lisp routine called visibility-add-eng.lsp
that worked before (as I remember on 2012version worked well) but don't know if it still working on 2017.
Check these threads:
http://forums.autodesk.com/t5/dynamic-blocks/ootb-multiple-visibility-states-solution/td-p/4961288
http://forums.autodesk.com/t5/dynamic-blocks/you-gotta-try-visibility-add-eng-v1-1/m-p/2521041/highl...
http://forums.autodesk.com/t5/dynamic-blocks/multiple-visibility-parameters-in-one-block/td-p/510353...
Here you could find original link to routine
http://www.private.peterlink.ru/poleshchuk/cad/Downloade.htm
P.S. Let me know if it will work.
Chris
Edit:
Generally this should be moved to DynamicBlocks - Forum
Libbya
visibility-add-eng does not work with later versions of AutoCAD.  I've posted up quite a few examples of how to use lookups and a double-lookup as a workaround.
Forma Design Contest
