Dynamic Blocks Forum
Move block except 1 point
7 REPLIES 7
Message 1 of 8
id_11
367 Views, 7 Replies
I want to move everything in this block except for the arrow point.
The issue is that the line doesn't stretch.
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
hwalker
in reply to: id_11
Your window is too small. It needs to be approximately the size of the red ring and you need to add everything highlighted to the stretch. See the image below
Howard Walker
Left Handed and Proud
Message 3 of 8
id_11
in reply to: id_11
Yes I have tried that but it doesn't work.
It looks easy to do but I don't think it is.
Message 4 of 8
id_11
in reply to: id_11
I should have mentioned that vertex you are looking at was not to move everything, just that point.
This is the closest I got.
The issue is that the Move takes the Point (you mentioned) but the Point has a chain action and that part gets moved twice.
Message 5 of 8
hwalker
in reply to: id_11
What is Stretch Elbow (Other Side) chained to?
Howard Walker
Message 6 of 8
id_11
in reply to: id_11
The other side I haven't gotten to yet. Once I get past this step then I can move forward.
I was wondering if it's possible to have a leader with 2 parts, at the moment I have a leader and a line.
Taking that further I know with a Multileader that you can get another leader by hovering over an Add Leader. But this may be asking for too much with this block.
Edit: These look like they have text associated with them though.
Message 7 of 8
vinodkl
in reply to: id_11
Hi @id_11
You are looking for something like this? See attachment
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 8 of 8
id_11
in reply to: id_11
Thank you vinodkl.
That does work. It looks like you applied Stretch to everything but the tip point.
Looks like I was overthinking it.
Forma Design Contest
AutoCAD Beta
