I want to move everything in this block except for the arrow point.
The issue is that the line doesn't stretch.
Solved by vinodkl. Go to Solution.
Your window is too small. It needs to be approximately the size of the red ring and you need to add everything highlighted to the stretch. See the image below
Howard Walker
I should have mentioned that vertex you are looking at was not to move everything, just that point.
This is the closest I got.
The issue is that the Move takes the Point (you mentioned) but the Point has a chain action and that part gets moved twice.
What is Stretch Elbow (Other Side) chained to?
Howard Walker
The other side I haven't gotten to yet. Once I get past this step then I can move forward.
I was wondering if it's possible to have a leader with 2 parts, at the moment I have a leader and a line.
Taking that further I know with a Multileader that you can get another leader by hovering over an Add Leader. But this may be asking for too much with this block.
Edit: These look like they have text associated with them though.
Hi @id_11
You are looking for something like this? See attachment
Thank you vinodkl.
That does work. It looks like you applied Stretch to everything but the tip point.
Looks like I was overthinking it.
