Dynamic Blocks Forum
Mleader to my block?
6 REPLIES 6
ritzofriya
441 Views, 6 Replies
is that possible to add an adjustable mleader to my block?
6 REPLIES 6
in reply to: ritzofriya
Can you explain a bit more on how you would like to use Mleader inside a block, please?
But it is possible to create a dynamic block just like Mleader and add that inside any block.
(Something Similar) You might wanna check this: https://youtu.be/nBMSbFBezsE
ritzofriya
Sorry, the video is live now please check.
timothy_crouse
Look at the TAGS layout tab There are many examples of MLEADER type dynamic blocks.
Best Regards
-Tim C.
Tags (1)
ritzofriya
in reply to: timothy_crouse
Thank you so much timothy
timothy_crouse
Some Background Info
It took a few iterations to get those blocks to the state they are in when they were uploaded.
The blocks currently use objects set to layer 0, bylayer color, line weight, plot style and transparency.
While the hatch uses "ByBlock" for all those settings.
This provides pretty good control for color control and printing.
Before they were setup like this they had predefined settings, Eg the line weights were a set size, the fill color and shading was predefined.  This format creating printing issues.  I seemed as though the plotter would do a good job but the HP printers would fade out some of the grays.  PLUS there were twice as many layers, as the hatching was on a separate layer.
Best Regards and Hope You can use them and learn from them
-Tim C.
Forma Design Contest
