I have not found an answer for my question here - could you please help me out? I am trying to add this formula into a dynamic block:
Distance3=(Distance2-100)/5
I also want the 4 lower fields to be always eql to Distance3
How can this be done? Your help is much appreciated!
Solved by hwalker. Go to Solution.
It looks like you're dividing the long rectangle into 5 in which case it's easy. Check the block in the drawing attached to see how it's done, you just need to add a load of move parameters to the main stretch and then change their DISTANCE MULTIPLIERS
Howard Walker
You also can try something like in the attached .dwg.
Jürgen Palme
