I've been trying to create a dynamic block for steel beams but I can't seem to get the actions correct. I've been trying to add parameters for changing the size of the block and making it stretchable. I'd like to have all the standard sizes available according to North American Steel Any help would be great. The drawing is below. The ray lines are to show the how the beams are to be shown in plan view.
Solved by timothy_crouse. Go to Solution.
I can send you an example if you would like.
But heads up, depending on how much detail you are going for it does get a bit complicated.
If you are capturing the radius corners you will most likely need to scale those and to keep things together geometric constraints are often used.
Another aspect is capturing all the beam data and placing it into a lookup table so you can properly size the various beams.
Best Regards
-Tim C.
FYI, They will make your drawing pretty heavy if you use more than a few.
My suggestion is to use them to create the image you need, save a copy with the dynamic block in-tact for maintenance purposes. But for the production drawing I would explode the block then recreate that instance of the exploded block.
This will pull all the extra weight out of the block.
Explode
purge
ctrl + X, cut objects
ctrl + sht + v paste as a new block
rename as applicable
Adjust base point as required inside the new block
Best Regrds
-Tim C.
