I have a dynamic block with Lookup Parameters which are used to show multiple visibilities.
I wanted to show tooltips permanently.
This is done with ""Lookup description String".
Is there a way to make sure theses always show, rather than just when hovering over the lookup parameter.
Solved by hwalker. Go to Solution.
No you can't have them display permanently.
Howard Walker
