Dynamic Blocks Forum
Lookup Grip not displaying
5 REPLIES 5
2025 Views, 5 Replies
I can't quite seem to figure out why the Lookup grip is not displaying.
I've attached the drawing, hopefully someone can help me out of a pickle? I spent a lot of time inputting the AISC information into this block.
5 REPLIES 5
jayhar
Try this GRIPOBJLIMIT <0>
Please upload AutoCAD 2013 format
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
The problem is that the lookup is read only.
It needs to say "allow reverse lookup". I made another lookup table with the same properties as your first column.
Im not sure why your stuck on read only for the original table though
I figured it out!
You can't repeat a named lookup property, and as I was trying to exclude the first specifier of the steel member, I had two "x 15" which forced it to be read only. Thanks for your help everyone!
Glad I could help!
hansDPQMN
put a name in the rightside table
Forma Design Contest
