I can't quite seem to figure out why the Lookup grip is not displaying.
I've attached the drawing, hopefully someone can help me out of a pickle? I spent a lot of time inputting the AISC information into this block.
Try this GRIPOBJLIMIT <0>
Please upload AutoCAD 2013 format
The problem is that the lookup is read only.
It needs to say "allow reverse lookup". I made another lookup table with the same properties as your first column.
Im not sure why your stuck on read only for the original table though
I figured it out!
You can't repeat a named lookup property, and as I was trying to exclude the first specifier of the steel member, I had two "x 15" which forced it to be read only. Thanks for your help everyone!
