Interior Elevation Tag
Message 1 of 10
Here we go again . . .
I have attached the interior elevation tag we use in our office.  What I am trying to achieve is the ability to have the solid poche be on/off for each "arrow" independently.  I would like to be able to have full control over the on/off state though where I can have any combination of the arrows on/off at the same time.
Also, looking to Libbya here, how would I add the same scale via LookUp ala the north arrow tag you helped me with last week.
Thanks again!!!
Replies (9)
Message 2 of 10
Libbya
I don't have time to explain more now and will be away for a bit.
The scale is the same solution as before.
For the multi-visibility I used the solution I posted in this thread:  http://forums.autodesk.com/t5/dynamic-blocks/ootb-multiple-visibility-states-solution/m-p/4961288#M1...
I would prefer the function of the second block where I used Flip parameters as inputs as you just have to click the grip.
Message 3 of 10
Lbbya,
Thank you again.  I am learning alot from your expertise in AutoCad!  I have applied what you did for the Elevation Tag to a Partition Type tag we used.  The tag works beautifully, but I cannot get rid of the "custom" field in the LookUp.  Obivously my eyes are looking over something that is triggering this.  When you have a free moment ( I say that with a chuckle because your free moments appear to be on this board helping all of us) can you have a quick look at this block?  Hopefully you will see what I have overlooked.
Thanks!
Message 4 of 10
ojuris
You had empty lookup table "Lookup5" for Lookup1 parameter
Regards
Juris
Message 5 of 10
Thank you.   I need to start working on these blocks using BACTIONBARMODE = 0.  I would have caught that then and I didn't even think to check!
Message 6 of 10
Dear I need a Dynamic Tag for numbering
in project drawings all time we need to make tag for equipments or pipes ....items reference point on site ext..
i need dynamic tag help us as per attached autocad drawing
Message 7 of 10
jrr
Hi Libbya,
Do you have a tag like this that would be for only one interior elevation but can use four different visibility views?
Thanks.
Message 8 of 10
Libbya
I'm not sure what you are asking for.  If you want only one arrow, there is no need for visibility states.  Just add a rotate to the arrow to allow it to point whichever direction you like.
Message 9 of 10
Hi
How do you change the hatch color from pink?
Message 10 of 10
Libbya
As stated above, it uses different visibility states and uses different lookups or the flip parameters as inputs to a double lookup to do the switching.
