How to Make a Double Lookup
Libbya
Mentor Mentor
Message 1 of 48
Libbya
Double lookups are so darn useful and slightly tricky to make so I figured I'd make a screencast in a dedicated thread that shows exactly how to make one and how to select each of the tables.
Replies (47)
Message 41 of 48
tstorzuk
Ok, not sure what's going wrong on my end....but when I copy the lookup parameter on the block authoring palette, and try to paste it....the PASTE is greyed out. Using AutoCAD 2023.Copy works fineCopy works fine  Paste is always greyed outPaste is always greyed out
Message 42 of 48
h_s_walker
@tstorzuk are you right clicking in the area ringed in the image below?
Howard Walker
Left Handed and Proud
Message 43 of 48
tstorzuk
@h_s_walker,
Yes. I've tried it there, and everywhere else on the palette.
This also happens when I try on the Parameter Sets tab, when I try copying and pasting the Lookup Set parameter. Paste is always greyed out.
Thought it might be a system setting like the BACTIONBARMODE, but I can't seem to find anything that might do this.
Message 44 of 48
h_s_walker
@tstorzuk Try importing the attached file when in the block editor (remove the .txt extension) See the image below for where you need to import it to
Howard Walker
Message 45 of 48
tstorzuk
@h_s_walker
Thanks, that helps get Lookup Set2 and Lookup Set3 into a new tab on my palette, a duplicate of the Parameter Sets tab.
It still doesn't change my inability to Paste parameters or parameter sets. But at least with that, I can start learning how to use the multiple lookups.
Message 46 of 48
h_s_walker
@tstorzuk Yeah I don't understand why you can't paste. It is a weird one
Howard Walker
Message 47 of 48
tstorzuk
I think it has a lot to do with the way that Autodesk supplies their product. Online only, with absolutely no way to check if the download is correct.
Most companies that provide a download also provide a CHECKSUM of some sort, to allow the end user to confirm that the download matches 100%.
Autodesk refuses to do that.
With a file size that keeps growing every release, there's a way higher possibility that something can and will go wrong with the download. That's why 98% of their resolutions to problems with their software is "uninstall, re-download, reinstall".
Message 48 of 48
Ed__Jobe
When you Paste, you are modifying your CUIx. You may not have enabled the ability to save the workspace. Type WSSETTINGS and check the Automatically Save Workspace Changes option.
Ed
How to post your code.
