How to keep a line in the middle between dynamic frame?
mmatanlevi
mmatanlevi
Hello guys,
Let's say I have a rectangle with a vertical short line which sits in the middle of its width. I mean that inside the rectangle I have a vertical line in equal distance from the left side and the right side of the rectangle. Image attached to demonstrate it. Let's say its a dynamic block meaning I can change the rectangle's width by linear stretch. I want that the short verical line would stay in the width's middle (if you're asking, it will used as a mirror / symmetry line). by the way, there is no necessity that the line would stay in the height's middle.
Must say that I looked for it in the internet but didn't find something for it although im sure it's already somewhere in the internet, probably my searching wasn't proper. If there is a method to do it, I think it will be valid for different circumstances as well. Hope there is a simple solution for it, and thank you very much in advance.
h_s_walker
Add either a stretch or move action to your linear parameter and change the distance multiplier to 0.5. See the image below
Howard Walker
Left Handed and Proud
Libbya
...or set the parameters base to mid and add a stretch to each end.
It is absolutely amazing that you did a search and didn't find a good result.  This is one of the most common questions asked on this forum - every week or so.  A quick search of 'centered stretch' gave 184 results!  Different search queries would probably net a hundred more on the same subject.
mmatanlevi
Thank you very much. Thanks to you reply I now know the distance multiplier function so its helped me to search more about this topic.
mmatanlevi
Thanks. I looked into some videos and forum solutions but didnt manage to do it in the software, probably due to my poor wording. Also im new to CAD and dynamic blocks.
