- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello guys,
Let's say I have a rectangle with a vertical short line which sits in the middle of its width. I mean that inside the rectangle I have a vertical line in equal distance from the left side and the right side of the rectangle. Image attached to demonstrate it. Let's say its a dynamic block meaning I can change the rectangle's width by linear stretch. I want that the short verical line would stay in the width's middle (if you're asking, it will used as a mirror / symmetry line). by the way, there is no necessity that the line would stay in the height's middle.
Must say that I looked for it in the internet but didn't find something for it although im sure it's already somewhere in the internet, probably my searching wasn't proper. If there is a method to do it, I think it will be valid for different circumstances as well. Hope there is a simple solution for it, and thank you very much in advance.
