How do i create a solid 3d shallow elliptical dome
How do i create a solid 3D shallow elliptical dome?
I need it to be 103mm x 75mm  and 3mm high.
I've tried scaling a block but cannot explode the reference block. I've tried creating a domed surface but i cannot convert it to a sold.
Please help 🙂
j.palmeL29YX
Something like the attached one?
Jürgen Palme
j.palmeL29YX
... and >>here<< a video.
BTW: This has nothing to do with Dynamic Blocks.
HTH
Jürgen Palme
j.palmeL29YX
See >>here<<
@john.vellek's answer #6 (and the limitation) is still relevant.
Jürgen Palme
Thats spot on cheers, how did you do it?
j.palmeL29YX
First you need some ellipses - one ellipse 103 x 75 and four elliptical arcs 75 x 6 and 103 x 6 (twice each).
Then create a loft using the elliptical arcs as cross sections and the full ellipse as guide.
Convert the resulting surface into solid and slice the half. >>Done<<
Jürgen Palme
j.palmeL29YX
... before you ask how to draw the ellipses - >>here<< one example. There are a lot of other possibilities too.
HTH
Did you find the answers helpful? If so please use the Accept as Solution or Kudos buttons below.
Jürgen Palme
