Hi Forum,
I have a dynamic block with several attributes. The default value of Attribute "Length" is linked (via "insert field") to the value of a parameter. The attribute value differs from the parameter as it has a prefix.
When you insert the block it prompts the user to fill in all the attributes. I want to stop the user being able to see (and edit) the Attribute "Length" when inserting the block. When creating the block I have tried different settings ("Invisible", "Verify" and "Preset" etc) but can't seam to prevent the user from seeing / editing the attribute "Length".
Thanks in advance for you help
Solved by hwalker. Go to Solution.
Change it to CONSTANT.
Howard Walker
@hwalker Thanks for the quick reply. I tried this and while it does stop the user being able to see (and edit) the Attribute "Length" it also stops the attribute linking (via "insert field") to the parameter.
It just displays the Attribute Tag and the Parameter name, instead of the parameter value (with the prefix)
Don't link it to the parameter. Link it to a line which is stretched by the parameter. If you don't want the line to be seen, put a visibility parameter in the block, select the line and change the visibility to hide for all states. See the attached drawing.
The linear parameter is stretching two lines, but I've hidden one in all visibility states so you can't see it you will only be able to see it if you toggle the icon in the image below
Howard Walker
Don't forget for the field to change a regen needs to be done on the drawing
Howard Walker
@hwalker Thanks yes I was aware of this disadvantage.
One of the reasons I want to link an attribute to a parameter is you can export attributes using AutoCAD LT but I am not aware of a way to export parameters in LT, as LT doesn't have the "DataExtraction" command.
Also some of the users of the block are using a Mac and the Mac version of Autocad doesn't have the "DataExtraction" command.
"ATTEXT" does work on Mac and PC but is limited to Attributes.
@hwalker If I use the above method (An attribute specified as "CONSTANT". In the "default" I insert a field linked to an objects length) I can extract attribute for a single block.
HOWEVER... when I insert multiple instances of that block and then extract the attributes using ATTEXT the data is blank???
What am I doing wrong?
Unfortunately I don't know as I never need to use data extraction
Howard Walker
