Dynamic Blocks Forum
Hide Attribute when inserting a block
9 REPLIES 9
Message 1 of 10
Mike_Y2
569 Views, 9 Replies
Hi Forum,
I have a dynamic block with several attributes. The default value of Attribute "Length" is linked (via "insert field") to the value of a parameter. The attribute value differs from the parameter as it has a prefix.
When you insert the block it prompts the user to fill in all the attributes. I want to stop the user being able to see (and edit) the Attribute "Length" when inserting the block. When creating the block I have tried different settings ("Invisible", "Verify" and "Preset" etc) but can't seam to prevent the user from seeing / editing the attribute "Length".
Thanks in advance for you help
Labels (2)
9 REPLIES 9
Message 2 of 10
hwalker
in reply to: Mike_Y2
Change it to CONSTANT.
Howard Walker
Left Handed and Proud
Message 3 of 10
Mike_Y2
in reply to: hwalker
@hwalker Thanks for the quick reply. I tried this and while  it does stop the user being able to see (and edit) the Attribute "Length" it also stops the attribute linking (via "insert field") to the parameter.
It just displays the Attribute Tag and the Parameter name, instead of the parameter value (with the prefix)
Message 4 of 10
hwalker
Don't link it to the parameter. Link it to a line which is stretched by the parameter. If you don't want the line to be seen, put a visibility parameter in the block, select the line and change the visibility to hide for all states. See the attached drawing.
The linear parameter is stretching two lines, but I've hidden one in all visibility states so you can't see it you will only be able to see it if you toggle the icon in the image below
Howard Walker
Message 5 of 10
Mike_Y2
@hwalker Brilliant! this works!!! Thanks a lot - I really appreciate your help.
Instead of using a visibility state, I converted the line into a "construction line" which is by default hidden 🙂
Message 6 of 10
hwalker
Don't forget for the field to change a regen needs to be done on the drawing
Howard Walker
Message 7 of 10
Mike_Y2
@hwalker Thanks yes I was aware of this disadvantage.
One of the reasons I want to link an attribute to a parameter is you can export attributes using AutoCAD LT but I am not aware of a way to export parameters in LT, as LT doesn't have the "DataExtraction" command.
Also some of the users of the block are using a Mac and the Mac version of Autocad doesn't have the "DataExtraction" command.
"ATTEXT" does work on Mac and PC but is limited to Attributes.
Message 8 of 10
Mike_Y2
@hwalker If I use the above method (An attribute specified as "CONSTANT". In the "default" I insert a field linked to an objects length) I can extract attribute for a single block.
HOWEVER... when I insert multiple instances of that block and then extract the attributes using ATTEXT the data is blank???
What am I doing wrong?
Message 9 of 10
hwalker
Unfortunately I don't know as I never need to use data extraction
Howard Walker
Message 10 of 10
Mike_Y2
@hwalker Thanks for the quick response.
I will create a new forum post
Forma Design Contest
AutoCAD Beta
