Message 1 of 11
03:19 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am building a dynamic HEA beam and i have some issues with the radius. When i change the size of the beam from HEA 120 to HEA 140 to HEA 160, 2 things happen:
- The radius doesnt change from r12 to r15 when going from HEA 140 to HEA 160.
- The thickness from the neck doesnt change on both sides when changing size between the HEA Beams. Also it isnt synmetrical when placing a center line in the block.
Can anyone who knows what the problem is check on my block and find out what the problem is and could you tell how to fix it for later parts and work.
Thank you for your time
