scale in annotative block
fabio_h_munhoz
fabio_h_munhoz
"english"
Hello!
I would like my dynamic block to read its own annotative scale, and with a text it gives the result
tanks
vinodkl
Hi @fabio.h.munhoz ,
Please find the screencast showing how you can do that. Let me know if you get stuck anywhere.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
fabio_h_munhoz
Hello!
I saw your video, and this was the last update I made before I stopped waiting for a light.
The problem with this method is that when I create a copy of this block, I change its scale, and play it in the viewport, its scale is not read, and when I regenerate it, all blocks are updated by the open viewport.
so, if I have a viewport with a 1: 1 scale, and another with a 1: 5 scale, when I update any scale (by typing "REGEN"), all blocks are updated by the scale that I regenerated.
vinodkl
Though they show a similar scale when regen, but objects will be plotted as per the viewport scale. If you're looking for Blocks to show different scale even when you regen in layout, that's not possible.
Here is similar thread which I found : https://forums.autodesk.com/t5/autocad-forum/way-to-retrive-current-block-annotative-scale-in-a-attr...
fabio_h_munhoz
@vinodkl, that's exactly what I wanted, the only drawback and the annotation on the cad screen appears with all the blocks with the wrong annotation.
However, after being plotted, the scales appeared correct, which is the most important!
I was ready and I didn't know.
Thank you!
