@alex.davisonQZ6ZH wrote:
That's exactly what I was after thanks.
If my reply resolves the issue or answers your question please mark "Accept as Solution", to help others in the community.
Before I answer to your second question:
Your problem description was, to set the distance over all and the distance of the steps independently. I would not be lucky with the result, if the steps don't fill the whole length. But if this is exactly what you where looking for, then all is ok.
Here I attach 2 other variants of similar blocks. The user only sets the length over all, the steps (their number and their dimension) are created automatically. In one of the variants the steps are never smaller 250, in the other variant the steps are never greater than 350. Give it a try.
What was the workflow ...
The first example above I solved using the power of Parametric constraints and dimensions.
First you have to apply geometric constraints to get a geometric stable model. Also I added a construction line as path for the array command. I you now use the arraypath command and choose the FillEntirePath option you get automatically as much steps as needed to fill the stair. (I don't know if you are familiar with Parametric. If not and you have further questions, ask again).
In the here attached two new examples I defined some User Parameters (to find in the Parameter Manager) and used this parameters to define the needed values of the array command. Depending on your knowledge about parametric you will either understand the principle yourself or you should ask what you not understood.
Jürgen Palme
