hatch on a linear parameter
_Matheus_
_Matheus_
I need a dynamic block so I can drag the vertex (image 1) up and down, but only the hatching of the drawing and the polygon lines appear (as in image 2), but I have no idea how to do this, the The distance between the hatches must always be equal.
If you have any questions about how the block should work, I am at disposal.
Accepted solutions (3)
Ed__Jobe
You don't need a block. If you draw a closed polyline and hatch it, with the hatch associative property true (HPASSOC = 1), then all you have to do is stretch the pline using the middle grips and the hatch will update.
Ed
How to post your code.
_Matheus_
yeah, but the lines has to be in 45° always, so i think it wouldn't work like that...
Ed__Jobe
The "lines" are not individual lines. A hatch is a pattern. If the pattern is at 45 degrees, it will remain that way. Attached is a sample dwg.
Ed
_Matheus_
i got it, yeah it may work, i just would need to "create" one of those i think, becouse i need it to be a fixed distance from line to line, and also it has to be filled, like in the second image, how can i do that?
Ed__Jobe
acad comes with a ton of hatch patterns. Use the HATCHEDIT command to experiment with the hatches. But if this isn't enough, you can create your own hatch pattern.
Ed
