Dynamic Blocks Forum
Forcing a padding between text and polyline
2 REPLIES 2
nathand3ASRP
318 Views, 2 Replies
Hello! I am wondering if I am able to add a parameter that would change the width of my polyline to always have the same padding around the text inside of it?
2 REPLIES 2
Libbya
in reply to: nathand3ASRP
Nope.  Changes to text cannot automatically drive changes to any parameters.
You can access MTEXT's text frame parameter from the Properties panel. With that turned on you can add a frame around the text. The frame offset can be controlled by the background mask parameter. A bit tricky, check the checkbox, set the offset factor then uncheck the mask checkbox.
A much better and flexible solution from the great Lee-Mac:
Associative Textbox
Autodesk Customer Advisory Groups
”Boost
