Flipped arcs do not stretch
murmanator
murmanator
This has me stumped. The attached block has a stretch ("Length") parameter and 4 flip parameters which are all controlled via a block parameter table with selections for "Concave" and "Convex". With the block in its initial state (Convex) the length stretch works fine. With the block in Concave the length stretch is not stretching the arcs. It stretches the other lines that are in the selection set but not the arcs.
I have tried using the individual flip grips so to eliminate the block table from the equation but that did the same thing. Ive tried including and not including the flips in the stretch selection set and that didnt change anything. I tried making a new stretch parameter, no good. I made a new block with just an arc and added a stretch and flip to that and it worked fine. So what is wrong with this block that the arcs are not stretching when flipped? Thanks for looking and for any help in advance.
vinodkl
The problem seems to eradicate if you replace those arcs with plines.(see attachment)
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
murmanator
That does indeed solve the problem. Although I sure would like to know why it was a problem in the first place, it just doesnt make sense to me. Nevertheless, thank you for the help!
cody.koern
THANK YOU @vinodkl
