Dynamic Blocks Forum
Flip won't preserve x,y axes
3 REPLIES 3
dan1619889
204 Views, 3 Replies
Hello everyone, I was trying to create a dynamic block with flip option, but it makes it flip at a "random" position, this only happens when the distance is changed, please, look at the sample and it will make more sense. Need help solving this. Thank you in advance.
3 REPLIES 3
j.palmeL29YX
in reply to: dan1619889
First you should remove the flip actions and parameters from the selection sets of the both stretch actions.
For a more detailed help please tell us what you want to achieve, which functionality you expect.
As a fist guess (I'm sure this is not yet exactly what you want) I added two move actions to move the flips. Maybe this helps you to see how to repair your block.
Jürgen Palme
dan1619889
in reply to: j.palmeL29YX
Thanks j.palmeL29YX, it is exactly what I wanted to achieve, just don't understand why do I have to remove the selection, is that what makes it act weird?
j.palmeL29YX
You can easily test it yourselfe. In the (well working) sample-pa.dwg modify the selection set of the both stretch actions: click on one stretch action, then right click and choose "Action Selection Set -> Modify Selection Set" and add the both flip parameters (inclusive their grips). Do the same with the other stretch action. Test your block - the old problem appears again.
Jürgen Palme
Forma Design Contest
