Hello everyone, I was trying to create a dynamic block with flip option, but it makes it flip at a "random" position, this only happens when the distance is changed, please, look at the sample and it will make more sense. Need help solving this. Thank you in advance.
Solved by j.palmeL29YX. Go to Solution.
First you should remove the flip actions and parameters from the selection sets of the both stretch actions.
For a more detailed help please tell us what you want to achieve, which functionality you expect.
As a fist guess (I'm sure this is not yet exactly what you want) I added two move actions to move the flips. Maybe this helps you to see how to repair your block.
Jürgen Palme
@dan1619889 wrote:
why do I have to remove the selection, is that what makes it act weird?
You can easily test it yourselfe. In the (well working) sample-pa.dwg modify the selection set of the both stretch actions: click on one stretch action, then right click and choose "Action Selection Set -> Modify Selection Set" and add the both flip parameters (inclusive their grips). Do the same with the other stretch action. Test your block - the old problem appears again.
Jürgen Palme
