Flip and Stretch not Playing Working
scottc44ZYK
scottc44ZYK
So I am trying to create a dynamic block that allows you to stretch an ellipse leader to some text and that part is working well. What happens is when I add a flip parameter the stretch works in the default state, but when the block is flipped the stretch pulls the ellipse in the wrong direction.
I've tried messing with bactionbarmode with no luck. Also can someone explain to me how the stretch frame works and what it's purpose is?
Libbya
The stretch frame creates a boundary.  If an object is in the stretch action's selection set and has some vertices within that boundary and some outside that boundary, then the vertices inside the boundary will be stretched while the vertices outside the boundary do not change.  If an object is in the stretch action's selection set and has either no vertices within the window or all vertices within the window, it will be moved rather than stretched.
I believe the attached screencast shows how to get your block working the way you would like.
